tacacs configuration for FTD's via FMC
Ranjith KR
Dear All,
we have a 2130 FTDs in high availability cluster (active standby) managed via FMC 4000. Firmware of both FTS and FMC is 6.2.3.6 with build 37. I need to configure the FTDs to get authentication via Tacacs (cisco ACS). I couldnt find exact steps or instruction to configure this. kindly help...!
Ranji
2 Accepted Solutions
Abheesh Kumar
FTD/FMC does not supports Tacacs, you need to go with Radius authentication.
Below doc will help you to configure ACS & FMC/FTD integration for external authentication with radius.
https://www.cisco.com/c/en/us/support/docs/security/firesight-management-center/200204-Integration-of-FireSIGHT-System-with-ACS.html
Abheesh
Marvin Rhoads
Like @Abheesh Kumar said, RADIUS is one option. The other supported external authentication method is LDAP.
TACACS+ is not currently supported (as of 6.2.3.7).
Abheesh Kumar
Abheesh
Marvin Rhoads
Dear Abheesh & Marvin,
sorry for the late response.
Thank you for your advice.
Ranji
Garbage! Radius isnt supported in FIPS mode. Cmon Cisco!
