Threat Data Updates on Devices SI DNS Lists and Feeds - Failure
Has anyone encountered the below error?
I have asa with sfr(6.2.3.6) and after upgrade to 6.4.0.4 i get this error.
Any hints?
Thanks and regards,
Konstantinos
8 Replies 8
I tried this command and it was successful.
admin@Firepower:~
sudo curl -vvk https://tools.cisco.com
It is the same channel with the other updates, right?
What might be wrong?
Konstantinos
Sorry for the late reply but hopefully this will be of use to others encountering the problem. It seems to affect 6.4.x and 6.5.x (as recent as 6.5.0.4).
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvs82369
My recent but limited experience with 6.6 hasn't shown it to be an issue there so far.
The workaround is a bit lacking in details:
Workaround:
Manually edit /ngfw/etc/sf/connector.properties on all failing devices and set connector_fqdn to the region defined in /ngfw/var/tmp/tds-cloud-events.json on that device.
Here's a more thorough explanation:
1. Log into the device(s) reporting the problem in FMC.
2. Change to expert mode and then sudo to su (superuser, aka "root").
3. Inspect the files "/ngfw/var/tmp/tds-cloud-events.json" and "/ngfw/etc/sf/connector.properties".
4. Make a backup of /ngfw/etc/sf/connector.properties
5. Edit /ngfw/etc/sf/connector.properties to add the value from the region variable in the json file to the "connector_fqdn=" line. (vi is built into RHEL so just vi the file, switch to insert mode with i, add the text, esc to command mode and then :wq to write and quit).
6. Verify your changes are as expected.
7. Wait a few minutes and the alarm should clear in FMC. No restart, deployment or other changes should be necessary.
> expert
NOTICE - Shell access will be deprecated in future releases
         and will be replaced with a separate expert mode CLI.
admin@fw1:~$ cd /ngfw/var/tmp
admin@fw1:/ngfw/var/tmp$ ls -al | grep tds
-rw-r--r--  1 root root   140 Apr 18 16:00 tds-cloud-events.json
-rw-r--r--  1 root root   351 Apr 19 02:34 tds_health.status
admin@fw1:/ngfw/var/tmp$ cat tds-cloud-events.json
   "events" : {
      "connection" : 0,
      "file" : 0,
      "intrusion" : 0
   "csd" : "1",
   "region" : "api-sse.cisco.com"
admin@fw1:/ngfw/var/tmp$ cd /ngfw/etc/sf/
admin@fw1:/ngfw/etc/sf$ cat connector.properties
registration_interval=180
connector_port=8989
connector_fqdn=
region_discovery_endpoint=https://api-sse.cisco.com/providers/sse/api/v1/regions
admin@fw1:/ngfw/etc/sf$ sudo su -
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
Password:
root@fw1:~# pwd
/root
root@fw1:~# cd /ngfw/etc/sf
root@fw1:sf# cp connector.properties connector.properties.old
root@fw1:sf# vi connector.properties
root@fw1:sf# cat connector.properties
connector_port=8989
connector_fqdn=api-sse.cisco.com
root@fw1:sf# cat /ngfw/etc/sf/connector.properties
connector_port=8989
root@fw1:sf#
Marvin, but what about sensors (7000-8000 series)  giving this same health alert.
I looked in /etc/sf   and /var/tmp   since NGFW is not a directory on the sensors,  but did not see these files.
I did find the health status that does show a failure, but no indications of what failed,   when I go into the  /var/sf/ directory and reviewing the files in  iprep_download, sidns_download, they appear to be up to date.
:/var/tmp# more tds_health.status
"modules" : {
"Siurl" : "Success",
"ThreatConf" : "Success",
"SHAList" : "Success",
"Siip" : "Failure",
"Clam" : "Success",
"CloudEvents" : "Success",
"Sidns" : "Failure",
"Bcdb" : "Success",
"DynamicAnalysis" : "Success"
"timestamp" : 1614091171
I checked my 3D7125 running 6.4.0.10 and it does not appear to have a connector.properties anywhere.
You might have to open a TAC case to resolve that one.
Hello Marvin,
thanks for you explanation, i am also getting similar alerts on my FMC.I have verified region and connector_fqdn filed on FTD but they seems to be okay, could you please suggest further.Below  are logs for your reference.
XXXX:/ngfw/var/tmp$ cat tds-cloud-events.json
"events" : {
"connection" : 1,
"file" : 1,
"prioritizedConnection" : 0,
"intrusion" : 1
"csd" : "0",
"region" : "api.eu.sse.itd.cisco.com"
XXXX:/ngfw/etc/sf$ cat connector.properties
connector_port=8989
connector_fqdn=api.eu.sse.itd.cisco.com
If you have verified the settings (as as you noted) and continue to have the error, I suggest opening a TAC case to investigate and resolve the issue.
Okay Marvin, will do the same. Thanks for your response.
hi Marvin
I just updateed our FTD's all over the world to 7.2.6 due to this security-flaw CSCwj10955 - and after that i have got this error in some regions - our FMC is located in northern Europe - and the FTD is in China.
Since the update the FTD in China has a warning "SI URL Lists and Feeds - failure"
If i look for similar configs like those just showen in this chat i have:
"csd" : "0",
"events" : {
"connection" : 0,
"file" : 0,
"connection_all" : 0,
"intrusion" : 0
"csn" : {
"has_been_asked_to_participate" : "1",
"cisco_success_network" : "1",
"is_sse_enrolled_first_use" : "1"
"region" : "api.eu.sse.itd.cisco.com",
"ltp" : null
This of course worries me a bit that the region is defined to something in europe and not asia but on the other hand it doesnt look as if the is a connectivity problme - curl connects fine:
curl -vvk https://api.eu.sse.itd.cisco.com
* Trying 18.158.186.55...
* TCP_NODELAY set
* Connected to api.eu.sse.itd.cisco.com (18.158.186.55) port 443 (#0)
* successfully set FIPS mode: 0
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: none
CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS handshake, [no content] (0):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Client hello (1):
* TLSv1.3 (OUT), TLS handshake, [no content] (0):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN, server accepted to use http/1.1
* Server certificate:
* subject: C=US; ST=California; L=San Jose; O=Cisco Systems Inc.; CN=api.eu.sse.itd.cisco.com
* start date: Feb 29 16:52:10 2024 GMT
* expire date: Feb 28 16:51:10 2025 GMT
* issuer: C=US; O=IdenTrust; OU=HydrantID Trusted Certificate Service; CN=HydrantID Server CA O1
* SSL certificate verify ok.
* TLSv1.3 (OUT), TLS app data, [no content] (0):
> GET / HTTP/1.1
> Host: api.eu.sse.itd.cisco.com
> User-Agent: curl/7.61.0
> Accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* TLSv1.3 (IN), TLS app data, [no content] (0):
< HTTP/1.1 403 Forbidden
< Date: Wed, 01 May 2024 05:32:30 GMT
< Content-Type: text/plain; charset=utf-8
< Content-Length: 9
< Connection: keep-alive
< Keep-Alive: timeout=5
< ETag: "6615b447-9"
< Cache-Control: no-store
< Pragma: no-cache
< Content-Security-Policy: default-src https: ;
< X-Content-Type-Options: nosniff
< X-XSS-Protection: 1; mode=block
< X-Frame-Options: SAMEORIGIN
< Strict-Transport-Security: max-age=31536000; includeSubDomains
* Connection #0 to host api.eu.sse.itd.cisco.com left intact
Any ideas - suggestions?
