ACL for DNS zone transfer and querries
gmaccisco1
I had an ACL for allowing DNS zone transfer and DNS queries to our DNS server that was allowing TCP/Domain and not UDP on port 53. I also must note that I didn't written that rule but inheritted it.
after I added another ACL and created a pool through PDM to allow UPD, Domain and port renge 53 to 53, the query started to work.
I was wondering if selecting TCP and Domian would do the trick by itself when it comes to PIX Firewalls?
Thx,
Masood
Richard Burts
Masood
While zone transfers use TCP most DNS querries use UDP. So I would expect that a rule selecting only TCP would not work.
Rick
Rick
