Active unit and PDM warning replication message
zillah2004
Level 7
Level 7
I have got two PIXs, Primary and Secondary
Primary (192.168.1001.1) is Standby
Secondary (192.168.1001.2) is Active
When I try to access the PDM from primary (Standby) I could not, but I was able to access PDM for Secondary (Active)
Secondary?s PDM Tools --> Command Line Interface --> config terminal,,,,I received this error message
<quote>
Result of firewall command: "config ter"
**** WARNING ***
Configuration Replication is NOT performed from Standby unit to Active unit.
Configurations are no longer synchronized.
</quote>
1- In the above message why it says Standby unit ?, while I have issued the command (config terminal ) within Active unit, not Standby unit
2- How can I find user privilege level from within PDM ?
PIX# show failover,,,,,,,,,,,,,,,,,,,,current one
Failover On
Cable status: Normal
Reconnect timeout 0:00:00
Poll frequency 15 seconds
Last Failover at: 00:53:35 UTC Sat Nov 11 2006
This host: Secondary - Active
Active time: 4705650 (sec)
Interface outside (10.1.1.130): Normal (Waiting)
Interface inside (192.168.100.1): Normal
Other host: Primary - Standby
Active time: 15838095 (sec)
Interface outside (192.168.105.2): Normal (Waiting)
Interface inside (192.168.100.2): Normal
This was the backup configuration:,,,,,,,,,,,,,,,,,,,,,in our Archive
PIX# show failover
Failover On
Last Failover at: 02:46:02 UTC Mon Oct 4 1993
This host: Primary - Active
Active time: 15931095 (sec)
Other host: Secondary - Standby
Active time: 4761990 (sec)
Stateful Failover Logical Update Statistics
Link : Unconfigured.
fmeetz
Level 8
Level 8
The error message is generated when PIX in failover are not syncing up.
Refer this url for more information,
http://www.cisco.com/warp/public/110/failover.html#copy
