ASA Backup using CLI
TW80CJ5
Level 6
Level 6
Hello Everyone,
I am trying to configure an ASA 5545x to backup to its local disk (disk:/0) using CLI on a daily basis. I would like to be able to write 7 backups to the disk before it starts overwriting existing backups, so having weeks worth of backup repository.
Here is my current config and it works great when I manually do it:ASA, CLI, NGFW Firewalls
CiscoASA# backup /noconfirm location disk0:/
I would like to be able to add the necessary commands for it to run daily and keep 7 daily backups before overwriting.
Is this possible?
Thanks in advanced!
Apologies, i was in impression ASA have full-blown EEM Features But looks like to has Limited.
I have tested below : ( below solution resolve your issue).
1. Since your requirement is 7 configuration file
2. i have made time to test-run every 80 seconds - change as per your requirement.
3. it keeps a copy the files up to 7 and keeps moving old to new
event manager applet backupconfig
event timer watchdog time 80 <<- this is in seconds to run
action 0 cli command "copy /noconfirm disk0:/running-config6 disk0:/running-config7"
action 2 cli command "copy /noconfirm disk0:/running-config5 disk0:/running-config6"
action 3 cli command "copy /noconfirm disk0:/running-config4 disk0:/running-config5"
action 4 cli command "copy /noconfirm disk0:/running-config3 disk0:/running-config4"
action 5 cli command "copy /noconfirm disk0:/running-config2 disk0:/running-config3"
action 6 cli command "copy /noconfirm disk0:/running-config1 disk0:/running-config2"
action 7 cli command "copy /noconfirm disk0:/running-config disk0:/running-config1"
action 8 cli command "copy /noconfirm running-config disk0:/running-config"
output none
it create a config like below :
ciscoasa# dir
Directory of disk0:/
23 -rwx 0 18:40:52 Mar 20 2016 use_ttyS0
67 -rwx 12805759 18:41:04 Mar 20 2016 anyconnect-linux-64-4.1.08005-k9.pkg
68 -rwx 16986568 18:41:12 Mar 20 2016 anyconnect-win-4.1.08005-k9.pkg
27 drwx 4096 22:36:52 Sep 20 2019 smart-log
24 drwx 4096 22:35:58 Sep 20 2019 log
63 drwx 4096 22:36:57 Sep 20 2019 coredumpinfo
75 -rwx 8173 23:43:37 Sep 20 2019 running-config1
71 -rwx 8173 23:43:37 Sep 20 2019 running-config
76 -rwx 8173 23:43:37 Sep 20 2019 running-config2
77 -rwx 8173 23:43:37 Sep 20 2019 running-config3
78 -rwx 8173 23:43:37 Sep 20 2019 running-config4
79 -rwx 8173 23:43:37 Sep 20 2019 running-config5
80 -rwx 8173 23:43:37 Sep 20 2019 running-config6
81 -rwx 8097 23:43:37 Sep 20 2019 running-config7
ciscoasa# show event manager
Last Error: Command failed @ 2019/09/20 23:42:15
event manager applet backupconfig, hits 8, last 2019/09/20 23:44:57
last file none
event watchdog 80 secs, left 66 secs, hits 8, last 2019/09/20 23:44:57
action 0 cli command "copy /noconfirm disk0:/running-config6 disk0:/running-config7", hits 8, last 2019/09/20 23:44:57
action 2 cli command "copy /noconfirm disk0:/running-config5 disk0:/running-config6", hits 8, last 2019/09/20 23:44:57
action 3 cli command "copy /noconfirm disk0:/running-config4 disk0:/running-config5", hits 8, last 2019/09/20 23:44:57
action 4 cli command "copy /noconfirm disk0:/running-config3 disk0:/running-config4", hits 8, last 2019/09/20 23:44:57
action 5 cli command "copy /noconfirm disk0:/running-config2 disk0:/running-config3", hits 8, last 2019/09/20 23:44:57
action 6 cli command "copy /noconfirm disk0:/running-config1 disk0:/running-config2", hits 8, last 2019/09/20 23:44:57
action 7 cli command "copy /noconfirm disk0:/running-config disk0:/running-config1", hits 8, last 2019/09/20 23:44:57
action 8 cli command "copy /noconfirm running-config disk0:/running-config", hits 8, last 2019/09/20 23:44:57
BB
14 Replies 14
balaji.bandi
Personally rather doing backup archive, offload from device is best practce, in case device crashes you will loose all.
use EEM Script to offload the config daily basis to TFTP or FTP Server with Date and Time.
BB
BB,
As absurd as this sounds, using scp, ftp, sftp is not an option. This is currently my only allowable device backup solution.
I need to be able to backup to local disk. I understand its a terrible option, but its the only one I have.
here is the EEM script for testing
event timer absolute time 00:05:00   <-- you can also run every hours if you want to
action 0 cli command "copy /noconfirm running-config location disk0:/running-config/\$h-\$t"    <-- this will save with time
output none
hope this help you.
BB
BB,
I am testing this now. I would like this to have a daily backup for 7 days only, with the new backups overwriting their old ones. Ideas?
Thanks for the help!!!!
Once this script workjing we can tune for you, delete the files older than 7 days
BB
It did not run within the last 5 minutes....
it runs at time. if you looking to run every 5min here is script
event timer cron cron-entry “*/5 * * * * ”
output none
BB
Ah, misundertstood.
I will try again with original. I dont want it to run every 5 minutes....
Look at the time example for reference :
https://www.cisco.com/c/en/us/support/docs/security/adaptive-security-appliance-asa-software/117883-config-eem-00.html#anc10
BB
BB,
I have tried : action 0 cli command "copy /noconfirm running-config location disk0:/Running_Config/\$h-\$t
with no luck
I have tried removing the word "location"
I have tried adding ".cfg" to the file name
I have tried diff variations of the "\" at the end
No luck!
output none
ciscoasa# dir
last file none
BB
BB,
I will test in the lab on Monday when I get into the office. I will let you know how it goes.
Thanks for helping!!!
BB,
I am using the EEM configuration you provided. It goes through all of the events at one time. I need it to run the event every 86400 seconds from the previous line.
For example all of the events run at the same time using the following:
output none
How would I get action 8 to run, wait one day, and run action 7, wait a day, run action 6, etc? Remember I only want to keep 7 days of configs on the local disks.
If you understand the EEM Script it has backup of 7 days :
event timer watchdog time 86400
output none
Hope this make sense ?
BB
