10-24-2019 08:03 AM
Greetings to all,
How can we directly Access a configured NGFW 2110 using putty when 2110 is being managed by FMC?
I tried using user credentials of FMC but it didnt work ie access denied
10-24-2019 08:11 AM
Hope you have not disabled SSH connecting using FMC - then you can SSH to kit and try using admin / other option is You can try console with admin login
=====️ Preenayamo Vasudevam ️=====
10-24-2019 10:06 AM
as @balaji.bandi noted the default username is admin. The admin password is set locally on the managed device and not shared/pushed from FMC.
FMC can set external authentication users and push them to the managed devices.
