Default Class-default Inspection
James Davies
Hi There,
On my ASA, I was looking at how inspection works, as Im not clear. I understand what it now does, but when I look at my running config, the section for policy-map global-policy looks like this:
policy-map global_policy
 class class-default
  user-statistics accounting
and nothing else? souldnt there be a list of the default inspection protocols? ftp, http etc?
and I notice the policy-map line is there twice?
Rishabh Seth
Level 7
Level 7
Hi James,
To perform inspection you basically select traffic (using ACL and class-map) based on your requirement.
Once you filter traffic you decide what inspections should be applied on the selected traffic (using policy-map).
At the end when you have coupled inspection with selected traffic then you apply this policy-map on an interface or at global level.
The show policy-map will list all the policy maps that you create. ASA has certain inspections enabled by default but that can removed or added.
In your configuration you have deleted contents of default policy-map "global_policy" and created another policy map "global-policy" with class class-default
  user-statistics accounting.
The lines in show run policy-map output are not same, you can see the " - " (dash)  and  " _ " (underscore) in the name.
Hope it helps!!!
R.Seth
Don't forget to mark the answer as correct if it helps in resolving your query!!!
5 Replies 5
Rishabh Seth
Level 7
Level 7
Hi James,
Hope it helps!!!
R.Seth
I didnt even notice that! thanks ;) how do I put this back? can I just delete the one I added by mistake by doing "no policy-map global-policy"
Yes you can delete the policy map using no policy-map <policy- name>. Only the default policy map cannot be deleted.
You can add the inspection to the default-policy. I have a sample output:
 class inspection_default
  inspect dns preset_dns_map
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
 class class-default
>> You can add or remove inspection based on your requirement.
R.Seth
Im getting this when I try and remove my one that I created by accident
ERROR: policy-map global-policy is being used and hence cannot be removed.
Got it!
Thanks very much.
no service-policy global-policy global
no class class-default
