Enabling DTLS with AnyConnect (SSL) Connection
rachelau_2005
I am trying to enabling DTLS for specific groups on ASA 5510.
however, when i type this :
asa-A(config)# webvpn
asa-A(config-webvpn)# svc ?
webvpn mode commands/options:
enable Enable SSL VPN Client
image SSL VPN Client package file path
profiles AC profiles package filepath.
it doesnt seem to support the command svc dtls enable
any idea?
Rachel
mchin345
Level 6
Level 6
To enable DTLS globally for a particular port, use the dtls port command:
[no] dtls port port_number
To enable DTLS for specific groups or users, use the svc dtls enable command in group policy webvpn or username webvpn configuration mode:
[no] svc dtls enable
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect23/administration/23admin3.html
lbarraza
For ASA 5545-x the command that we used were:
ASA(config)# group-policy <Connection Profile name> attributes
You can use the "sh run group-policy" command to verify what group policy attributes you want to enable dtls.
in our case we used.
ASA(config)# group-policy sslvpn attri
ASA(config-group-policy)#webvpn
ASA(config-group-webvpn)#anyconnect ssl dtls enable
 To verify dtls is enabled
ASA(config-group-webvpn)# do sh run group-policy <connection profile>
