Etherchannel on ASA
lukaszkhalil
Hello
Is there a possibility to aggregate multiple ports into one logical channel on the Cisco ASA ?
Thank your advance
Lucas
thiland
Level 3
Level 3
This is supported as of 8.4.1.
EtherChannel support (ASA 5510 and higher)
You can configure up to 48 802.3ad EtherChannels of eight active interfaces each.
Note You  cannot use interfaces on the 4GE SSM, including the integrated 4GE SSM  in slot 1 on the ASA 5550, as part of an EtherChannel.
We introduced the following commands: channel-group, lacp port-priority, interface port-channel, lacp max-bundle, port-channel min-bundle, port-channel load-balance, lacp system-priority, clear lacp counters, show lacp, show port-channel.
http://www.cisco.com/en/US/docs/security/asa/asa84/release/notes/asarn84.html#wp432043
francisco_1
Level 7
Level 7
etherchannel is not yet supported on ASA
thiland
Level 3
Level 3
Ok, thank you for this info.
