firepower management center
edwincharles
Dears,
I have installed the firepower management center on the VM
I have issue with access the GUI of firepower management center
system process are starting , please wait
17 Replies 17
There is not a /var/log/messages in the system I am using.
root@FMC:/# /var/log/ CSCOpx/ packages/ scripts/ vjdbc/
audit/ removed_packages/ seshat/ httpd/ removed_scripts/ setup/
mojo/ sa/ sf/
Where may one find the logs you mention in your post?
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
/var/log is the folder. messages is the file.
From /var/log, type "ls -al | grep messages" (without the quotes).
Thanks. Will check that out.
