FTD 2110 and IKEv1 VPN site to site tunnels to 3rd parties
Nick Currie
Hi guys, I am about to pull the trigger on refreshing our old ASA's with 2110 FTD devices however I was just wanting to double check that they will support Site to site IKEv1 VPN to 3rd party equipment? (not sure if its cisco etc)
I read on the firewall.cx site its only supported between FTD and ASA devices?
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-firewalls/1197-cisco-asa-firepower-threat-defense-ftd-installation-management.html
"Site-to-Site VPN. Only supports Site-to-Site VPN between FTD appliances and FTD to ASA"
Francesco Molino
If you check here there's no such limitation:
https://www.cisco.com/c/en/us/td/docs/security/firepower/610/configuration/guide/fpmc-config-guide-v61/firepower_threat_defense_vpn_deployments.pdf
Unfortunately or fortunately for me :-) all site to sites I've done are with Cisco devices in azure or aws these last weeks
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
