ASA 8.4(4)1
ASDM 6.4(9)
Cisco Novice - No familiarity with the CLI at all.
I'm trying to open up some sports for a VOIP service.
5060-5070 In/Out UDP SIP Inbound/Outbound
16384-32768 In/Out UDP RTP Media Ports
Internal IP: 192.168.1.200
I tried following this tutorial: http://www.gregledet.net/?p=537
However I get the following result:
[OK] object network RTPMediaPortsB
[ERROR] nat (inside,outside) static interface service udp 16384-32768 16384-32768
ERROR: % Invalid input detected at '^' marker.
[OK] object network SIPInboundOutboundB
[ERROR] nat (inside,outside) static interface service udp 5060-5070 5060-5070
[OK] no access-list outside_access_in line 48 extended permit object-group VOIP any 38.104.182.0 255.255.255.0
[OK] no access-list outside_access_in line 45 extended permit object-group VOIP any object CudaTel
[OK] no access-list outside_access_in line 44 remark Opened ports for VOIP service
[OK] access-list outside_access_in line 46 extended permit object-group VOIP any object CudaTel
Can anyone help me?
