I can not acces to DMZ from vpn clients ASA 5505 v 9.1(1)
enrique.jara
ASA Version 9.1(1)
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd 2KFQnbNIdI.2KYOU encrypted
names
ip local pool Pool_Vpn 172.26.0.10-172.26.0.19 mask 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 5
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 10.0.10.1 255.255.255.0
interface Vlan5
no forward interface Vlan1
nameif DMZ
security-level 50
ip address 10.0.0.200 255.255.255.0
boot system disk0:/asa911-k8.bin
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Router
host 10.0.10.2
description Router Ya.com
object network DMZ_Internet
subnet 10.0.0.0 255.255.255.0
object network NETWORK_OBJ_172.26.0.0_27
subnet 172.26.0.0 255.255.255.224
object network NETWORK_OBJ_192.168.1.0_24
subnet 192.168.1.0 255.255.255.0
object network DMZ_outside
object network PC
host 192.168.1.2
object network Fuera
subnet 172.26.0.0 255.255.255.0
object network Escritorio_Remoto
host 192.168.1.2
object network COD3
host 192.168.1.2
object network COD4
host 192.168.1.2
object network EmuleTcp
object network EmuleUdp
object network terminal
object network Terminal
host 192.168.1.2
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service DM_INLINE_SERVICE_1
service-object tcp destination eq 5544
service-object udp destination eq 6699
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 any4 interface outside
access-list outside_access_in extended permit tcp any any eq 3389
access-list outside_access_in extended permit ip any any
access-list outside_access_in extended deny ip any any
access-list global_access extended permit ip any4 any4 inactive
access-list inside_access_in extended permit object-group TCPUDP any4 object PC range 27000 27050 inactive
access-list inside_access_in extended permit object-group TCPUDP any4 object PC eq 3074 inactive
access-list inside_access_in extended permit ip any4 any4
access-list inside_access_in extended deny ip any any
access-list DMZ_access_in extended permit ip 10.0.0.0 255.255.255.0 10.0.10.0 255.255.255.0
access-list DMZ_access_in extended permit ip any4 any4
access-list Tunel_Casa_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list Tunel_Casa_splitTunnelAcl standard permit 172.26.0.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
logging class vpn trap informational asdm informational
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
icmp permit any DMZ
asdm image disk0:/asdm-711-52.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (DMZ,outside) source dynamic any interface
nat (outside,outside) source static NETWORK_OBJ_172.26.0.0_27 NETWORK_OBJ_172.26.0.0_27 destination static NETWORK_OBJ_172.26.0.0_27 NETWORK_OBJ_172.26.0.0_27 route-lookup
nat (inside,outside) source static any any destination static NETWORK_OBJ_172.26.0.0_27 NETWORK_OBJ_172.26.0.0_27
nat (inside,outside) dynamic interface
nat (DMZ,outside) dynamic interface
nat (outside,inside) static PC
object network COD3
nat (inside,outside) static interface service tcp 3074 3074
object network COD4
nat (inside,outside) static interface service udp 3074 3074
nat (inside,outside) static interface service tcp 3389 3389
nat (inside,outside) after-auto source dynamic any interface
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
access-group DMZ_access_in in interface DMZ
access-group global_access global
route outside 0.0.0.0 0.0.0.0 10.0.10.2 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication secure-http-client
http server enable
http 192.168.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map DMZ_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map DMZ_map interface DMZ
crypto ca trustpool policy
crypto ikev1 enable inside
crypto ikev1 enable outside
crypto ikev1 enable DMZ
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
ssh version 2
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.15-192.168.1.25 inside
dhcpd dns 8.8.8.8 8.8.4.4 interface inside
dhcpd enable inside
dhcpd address 10.0.0.100-10.0.0.115 DMZ
dhcpd dns 8.8.8.8 8.8.4.4 interface DMZ
dhcpd auto_config outside vpnclient-wins-override interface DMZ
dhcpd enable DMZ
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy Tunel_Casa internal
group-policy Tunel_Casa attributes
dns-server value 8.8.8.8 8.8.4.4
vpn-idle-timeout none
vpn-tunnel-protocol ikev1
password-storage enable
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Tunel_Casa_splitTunnelAcl
tunnel-group Tunel_Casa type remote-access
tunnel-group Tunel_Casa general-attributes
address-pool Pool_Vpn
default-group-policy Tunel_Casa
tunnel-group Tunel_Casa ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect ipsec-pass-thru
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:ed92d9460fe9457fee4def565cb30f9f
: end
4 Accepted Solutions
shamax_1983
Level 3
Level 3
You need have a dynamic PAT on DMZ interface. But missing NAT-exempt(identity nat) for traffic passing between your DMZ interface and VPN clinets.
Try adding these lines
object network VPN_pool
range 172.26.0.10 172.26.0.19
nat (DMZ,outside) source static any any destination static VPN_pool VPN_pool
Hi Enrique,
Thanks for the rating..
your  "inside <-> VPN"  traffic also needs a identity nat. . You may need to add this line as well.
nat (inside,outside) source static any any destination static VPN_pool VPN_pool
I would consider changing the whole NAT setup a bit
You could start by removing all the following NAT configurations and replacing them with new ones (provided I have understood the situation correctly)
no nat (DMZ,outside) source dynamic any interface
no nat  (outside,outside) source static NETWORK_OBJ_172.26.0.0_27  NETWORK_OBJ_172.26.0.0_27 destination static NETWORK_OBJ_172.26.0.0_27  NETWORK_OBJ_172.26.0.0_27 route-lookup
no nat (inside,outside) source static any any destination static NETWORK_OBJ_172.26.0.0_27 NETWORK_OBJ_172.26.0.0_27
no nat (DMZ,outside) source static any any destination static VPN_pool VPN_pool
no nat (inside,outside) source static any any destination static INSIDE_pool INSIDE_pool
It would also seem to me that the following configuration would be useless after configuring what I'm suggesting, so you could remove these also
Leave all other NAT configurations as they are.
The new configurations could be for example
Default PAT for DMZ (First removed rule above)
nat (DMZ,outside) after-auto source dynamic any interface
NAT0 / NAT Exempt style configuration for the VPN Pool for both DMZ and INSIDE networks
  • NAT configurations that should allow traffic from VPN-POOL to both INSIDE and DMZ
object network VPN-POOL
object network INSIDE
object network DMZ
nat (inside,outside) source static INSIDE INSIDE destination static VPN-POOL VPN-POOL
nat (DMZ,outside) source static DMZ DMZ destination static VPN-POOL VPN-POOL
Also one thing that caught my eye was that you have this ACL attached globally yet you have interface ACLs
no access-group global_access global
no access-list global_access extended permit ip any4 any4 inactive
As the only rule in the ACL is set to "inactive" I would suggest removing the "access-group" command for it.
Also please remove this line from the Split Tunnel ACL
no access-list Tunel_Casa_splitTunnelAcl standard permit 172.26.0.0 255.255.255.0
Atleast it seems to me something that should not be there as the ACL defines the networks that need to be accessed through the VPN connection and that network range is the VPN-POOL.
Also consider clearing all NAT translations before testing connections (clear xlate)
If you decide to change the configurations as I suggested, please take a backup of the current configuration so you can change back to the old configuration if needed.
- Jouni
Did you mean to say that you can access the DMZ network from the VPN Client but NOT the INSIDE network?
It seems that for the most part your configurations have stayed the same compared to the situation when you made the changes that corrected the situation.
Relating to the NAT configuration it seems you have added this configuration line
To my understanding its not needed as we previously configured NAT rules for the LAN to VPN and DMZ to VPN traffic already with the following configurations
You could perhaps try to remove the configuration
Or did I missunderstand the problem somehow?
- Jouni
9 Replies 9
shamax_1983
Level 3
Level 3
Hello again,
Now I lost the ping with my hosts in the inside interface, is this posible ?
ASA Version 9.1(1)
hostname CASA
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan5
nameif DMZ
security-level 50
banner exec Solo Enrique Jara Ceña Puede administrar este equipo. Si no eres él, desconectate
banner login Solo Enrique Jara Ceña Puede administrar este equipo. Si no eres él, desconectate
banner motd Solo Enrique Jara Ceña Puede administrar este equipo. Si no eres él, desconectate
banner asdm Solo Enrique Jara Ceña Puede administrar este equipo. Si no eres él, desconectate
ftp mode passive
host 10.0.10.2
object network PC
host 192.168.1.2
host 192.168.1.2
object network COD3
host 192.168.1.2
object network COD4
host 192.168.1.2
host 192.168.1.2
object network INSIDE_pool
range 192.168.1.2 192.168.1.254
protocol-object udp
protocol-object tcp
access-list Tunel_Casa_splitTunnelAcl standard permit 10.0.0.0 255.255.255.0
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
icmp permit any DMZ
arp timeout 14400
object network COD3
object network COD4
http server enable
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
ssh version 2
console timeout 0
dhcpd enable inside
dhcpd enable DMZ
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
Cryptochecksum:72104b62edd35e106376f9181539afa8
: end
Hi Enrique,
you tried this I mention, but I still do not have access to the equipment on the inside interface
object network DMZ
- Jouni
Hi !
I believe that with these changes, everything works perfectly now. I have obviously had a big problem with the NAT configuration.
Thank you for everything
Hello, I'm having trouble, now when I make a VPN connection, I only see the machines in the DMZ, but I can see the machines that are connected to the inside interface.
Can you help me again please?
ASA Version 9.1(1)
hostname CASA
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan5
nameif DMZ
security-level 50
ftp mode passive
host 10.0.10.2
object network PC
host 192.168.1.2
object network COD3
host 192.168.1.2
object network COD4
host 192.168.1.2
host 10.0.0.50
object network DMZ
object network Emule_TCP
host 192.168.1.2
object network Emule_UDP
host 192.168.1.2
object network ENRO
host 10.0.0.50
object network VNC
host 10.0.0.50
object network FTP
host 10.0.0.50
object network FTP_20
host 10.0.0.50
protocol-object udp
protocol-object tcp
service-object udp destination eq 5554
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 any any
access-list outside_access_in extended permit tcp any any eq ftp-data
access-list outside_access_in extended permit tcp any any eq 5900
access-list outside_access_in extended permit ip any any inactive
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
icmp permit any DMZ
arp timeout 14400
nat (inside,outside) static interface service tcp 3389 33899
nat (inside,outside) static interface service tcp 5544 5544
nat (inside,outside) static interface service udp 5554 5554
object network ENRO
nat (DMZ,outside) static interface service tcp 3389 3389
object network VNC
nat (DMZ,outside) static interface service tcp 5900 5900
object network FTP
nat (DMZ,outside) static interface service tcp ftp ftp
nat (DMZ,outside) static interface service tcp ftp-data ftp-data
http server enable
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
ssh version 2
console timeout 0
dhcpd enable inside
dhcpd enable DMZ
username telcon password xxxxxx encrypted privilege 0
username telcon attributes
service-type remote-access
username goloso password xxxxxxxx encrypted privilege 15
username enrique password xxxxxxxxxxxx encrypted privilege 0
username enrique attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
Cryptochecksum:9e92d2149401cfb9e172b9737dc02b64
: end
- Jouni
Jouni thank you very much for everything, if you understood what I needed, and now everything seems to work perfectly.
regards
