is it possible to have three ISP connections to Cisco ASA 5510
Mogal Peerbasha
Hi all,
We have a Cisco ASA 5510 firewall in one our customer location and currently we are using two ISP as a failover case. But the customer wants to add another ISP as a back up connection. Is it possible to have three ISPs with cisco ASA 5510 firewall.
Please do reply.
Peerbasha
prateeve
Yes, it is possible . Right now it would be like outside and backup interface and configuration would be something like below (just an example):
route outside 0.0.0.0 0.0.0.0 10.200.159.1 1 track 1
route backup 0.0.0.0 0.0.0.0 10.250.250.1 253
sla monitor 123
 type echo protocol ipIcmpEcho 4.2.2.2 interface outside
 num-packets 3
 frequency 10
sla monitor schedule 124 life forever start-time now
Suppose now you add new interface backup2, then you need to configure following commands:
route backup2 0.0.0.0 0.0.0.0 10.250.250.1 254
sla monitor 124
 type echo protocol ipIcmpEcho 4.2.2.2 interface backup
 num-packets 3
 frequency 10
Now, if primary goes down it will move to backup and if backup goes down it will move to backup2.
Hope it will help.
- Prateek Verma
prateeve
sla monitor 123
 num-packets 3
 frequency 10
sla monitor 124
 num-packets 3
 frequency 10
Hope it will help.
- Prateek Verma
Hi Prateek Verma,
Thanks and it is working fine with above solution.
I would like to ask one question, for Outside route we are traking the reachability with track 1, where as do we need to use the same for backup route to track the reachability with track 2 i.e as follows
    Example:
             route backup 0.0.0.0 0.0.0.0 10.250.250.1 253 track 2
             track 1 rtr 123 reachability
             track 2 rtr 124 reachability
Please clarify.
Peerbasha
Hi Peerbasha,
Yes, I forgot to mention that, my mistake .
- Prateek Verma
