match active-ftp , match passive-ftp asa commands
plao
From Command reference:
http://www.cisco.com/en/US/docs/security/asa/asa84/command/reference/m.html#wp2115726
match active-ftp and match passive-ftp commands
These command can be configured in an FTP class map or policy map.
Are these commands still valid? I can't locate these commands in my ASA running 8.4.1
ASA5505(config)# class-map type inspect ftp ftpcm
ASA5505(config-cmap)# match ?
mpf-class-map mode commands/options:
  filename         Match a filename for FTP transfer
  filetype         Match a filetype for FTP transfer
  not              Negate this match result
  request-command  Match a FTP request command
  server           Match a FTP server
  username         Match a FTP user
Pat
varrao
Level 10
Level 10
Hi Plao,
The command is still there but you are looking at the wrong place, this is a policy-map command:
hostname(config)# policy-map type inspect ftp inspect-strict-ftp
hostname(config-pmap)# parameters
hostname(config-pmap-p)# match active-ftp
hostname(config-pmap-p)# reset
hostname(config-pmap-p)# match passive-ftp
hostname(config-pmap-p)# reset log
hostname(config-pmap-p)# exit
You are looking under the class-map.
Hope this helps
Varun
Varun Rao
5 Replies 5
varrao
Level 10
Level 10
Hi Plao,
Hope this helps
Varun
Varun Rao
plao
Thank you very much
No Problem
Please mark this thread as answered and do rate helpful posts.
-Varun
Varun Rao
plao
Humm, under my FTP inspect policy-map, parameters setting, I don’t see those match command?
ASA5540(config)# policy-map type inspect ftp strict
ASA5540(config-pmap)# parameters
ASA5540(config-pmap-p)# ?
MPF policy-map parameter configuration commands:
  exit             Exit from MPF policy-map parameter configuration submode
  help             Help for MPF policy-map parameter submode commands
  mask-banner      Mask greeting banner from FTP server
  mask-syst-reply  Mask reply to syst command
  no               Negate or set default values of a command
  quit             Exit from MPF policy-map parameter configuration submode
ASA5540(config-pmap-p)# match active-ftp
ERROR: % Invalid input detected at '^' marker.
ASA5540(config-pmap-p)# sh ver
Cisco Adaptive Security Appliance Software Version 8.4(1)
Device Manager Version 6.4(1)
Hi Plao,
I am on my way to office, would verify it on my firewall and let you know.
-Varun
Varun Rao
