I am trying to add a multi context ASA in Solwarwinds...i successfully added the admin context where interface details , HA etc are visible but the other 2 context are showing as a Grey node and no interface data is available...i checked the logs on Firewall and i can see continous queries from Solwarwinds IP to ASA Contexts... These contexts are integrated to solarwinds via one of the inside interfaces..am i missing some configuration ? also when i checked the SNMP configuration if this contexts via ASDM under Management Settings -SNMP ..the listening port is listed as 161 but its a disabled box where i cannot change the port number .. is this expected behaviour or i need to enable these interfaces somehow to send snmp data to solwarwinds..
