Multiple interfaces for Hide NAT issue
jonathanaxford
Level 8
Level 8
Hey Experts,
I'm struggling with a NAT config and would appreciate some help to get myself going! Its a Cisco FWSM running version 4 in a 6509.
We have a requirement to "Hide NAT" traffic coming from a Load Balancer IP behind the interface of the network it is accessing. So far this works fine:
global (first_interface) 1 interface
nat (inside) 1 10.10.10.10 255.255.255.255
In this example, 10.10.10.10 is the IP that the LB uses to send traffic and when it sends to the servers behind the first_interface it is translated successfully and all is good.
Now, I need to add a second interface to the mix, so when the LB sends traffic to the second_interface, the traffic is also hidden, but this time its hidden behind the second_interface.
I can't add a second NAT pool entry that matches the same source IP, as I get a duplicate NAT entry error. If I try adding  a second global statement as follows:
global (second_interface) 1 interface
Then it also doesn't work - I'm guessing because the NAT process is kicking in before the routing is decided? It's late, so I'm fed up of looking at it. Can someone let me know if I am missing something obvious here!?
Any information would be much appreciated!
Cheers
Jon
Kureli Sankar
You cannot add the following as the source IP can only live behind one interface.
nat (second_interface) 1 10.10.10.10 255.255.255.255
You can however add the following:
-Kureli
