OSPF Input Packets Ignored
jonathangamlin
I am trying to configure my ASA 5545 firewall in area 0 but when I do so, the neighbor relationship never establishes.  A debug on OSPF gives only one response:
OSPF: Input packet ignored.
Here is my configuration:
ASA 5545:
router ospf 65310
router-id 10.222.171.161
network 10.0.0.0 255.0.0.0 area 0
area 0 authentication message-digest
log-adj-changes
interface GigabitEthernet0/1.20
vlan 20
nameif INSIDE
security-level 100
ip address 10.222.171.161 255.255.255.248
ospf message-digest-key 1 md5 *****
ospf authentication message-digest
4948E:
router ospf 65310
router-id 167.68.126.136
log-adjacency-changes
passive-interface default
no passive-interface Vlan20
network 10.222.171.164 0.0.0.0 area 0
interface Vlan20
description wan-eag-diste-fw1 INSIDE
ip address 10.222.171.164 255.255.255.248
ip ospf message-digest-key 1 md5 test
I have already verifed that the key matches on both neighbors.  Any idea why the ASA is ignoring the input packets?
Hello Jonathan
can you try to do the following
router ospf 65310
no network 10.0.0.0 255.0.0.0 area 0
network 10.222.171.160 255.255.255.248 area 0
Harish.
Hi Harish,
I actually tried that and it did not work either.  Interesting enough though, I added failover configuration with the secondary ASA and the OSPF neighbor relationship came up with the directly connected switch.  I am not sure why this would have caused the neighbor relationship to work.
Thanks for the reply!
ICT Networks
Have you got matching mtu? What does debug ospf events and debug ospf packet give you?
Sent from Cisco Technical Support Android App
Hi Barrie,
The MTU's do match.  The debug only shows "OSPF: Input Packet Ignored."  Interesting enough though, I added failover configuration with the secondary ASA and the OSPF neighbor relationship came up with the directly connected switch. I am not sure why this would have caused the neighbor relationship to work.
