port-forwarding using manual nat (not auto-nat) not working
abcdrohan
I am running 8.6(1)2 on my ASA
It's a lab environment and I am trying to figure out how to do port-forwarding using manual nat
For e.g. I tried following but none of them work (Only one of the following was activated on the FW at a time)
   nat (outside,inside) source static any any destination static h-3.3.3.3 local_ip service tcp-www tcp-8080
   nat (outside,inside) source static  h-3.3.3.3 6.3.3.6  service tcp-www tcp-8080
  nat (inside,outside) source static local_ip h-3.3.3.3 destination static any any service 8080 80
Have anyone one of you been able to do port forwarding using manual nat on post 8.2?
Thanks!
I would still not configure in such a way.
I tend to avoid using the "any" keyword in the NAT configurations unless its used to define source addresses for the default Dynamic PAT rule.
You seem to have flipped the NAT rules the other way around also.
You are using the "outside" as the source and "inside" as the destination.
- Jouni
Jouni Forss
A very basic Static PAT / Port Forward on the new software could be something like this (though I personally use Network Object NAT for this)
object network HOST-REAL
host 10.10.10.10
object network HOST-MAPPED
host 1.1.1.1
object service RDP
service tcp source eq 3389
nat (inside,outside) source static HOST-REAL HOST-MAPPED service RDP RDP
access-list OUTSIDE-IN permit any object HOST-REAL eq 3389
access-group OUTSIDE-IN in interface outside
That should pretty much be it.
Naturally there is always a change that some existing other NAT configuration overrides this NAT configuration and traffic will therefore never get matched against this Static PAT configuration
Naturally you can confirm which NAT rule is hit with the "packet-tracer" command.
For example considering my above Static PAT configuration I could try this
packet-tracer input outside tcp 1.2.3.4 12345 1.1.1.1 3389
Hope this helps
Remember to mark the reply as the correct answer if it answered your question. Or ask more
Also I made a NAT 8.3+ document earlier here on the forums if you want to take a look. Though at the moment it only gives examples of some very basic NAT setups
https://supportforums.cisco.com/docs/DOC-31116
- Jouni
I actually figured it out
What I was doing was that I had created tcp-8080 with
service tcp source eq 8080
while the predifned tcp-www is of type
service tcp destination eq www
I had to change
tcp-8080 to
service tcp destination eq 8080 and got it working using
nat (outside,inside) source static any any destination static 6.3.3.6 local_ip service tcp-8080 tcp-www
Thanks!
- Jouni
