regular translation creation failed for protocol 50 src inside:192.168.1.20 dst outside:xxx.xxx.xxx.58
burann4242
When I try to use my vpn client to connect to another ASA firewall from home, my home ASA seems to block it. The VPN seems to connect, I cant use any services.
Been reading various description of the problem and tried to fix it, but no luck so far. Hope someone could help here, I'm just starting out with the ASA.
Config follows:
: Saved
ASA Version 8.4(1)
hostname troll
domain-name hemma
enable password qo.OrRMCak4uVCfZ encrypted
passwd XXXXX encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
mac-address AAAA.BBBB.CCCC
nameif outside
security-level 0
ip address dhcp
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns domain-lookup inside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 8.8.4.4
domain-name hemma
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network outside-network
host 123.123.123.123
description outside-network
access-list inside_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm errors
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) after-auto source dynamic any interface
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 123.123.123.123 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication enable console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto isakmp nat-traversal 3600
crypto ikev1 enable outside
telnet timeout 5
ssh scopy enable
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 60
ssh version 2
console timeout 0
management-access inside
dhcp-client client-id interface outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd dns 192.168.1.1 8.8.4.4 interface inside
dhcpd domain troll interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username test password password encrypted privilege 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect ipsec-pass-thru
policy-map type inspect ipsec-pass-thru map_name
parameters
  esp
  ah
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:e775asc3beasc8basc8234356457782234asc34a234sc2
: endf
Maykol Rojas
As you can see the translation is failing for IP protocol 50. Since you are running PAT on your home ASA, when the client connects and starts encapulating everything on ESP (IP protocol 50) it hides the transport layer and above. Since PAT depends on ports in order to create the translation, you are goint to get this error message.
You may say, well, I can connect if I use my $80 lynksys router, or across a cisco router. That is because those devices let the IP protocols pass thru without being inspected. The ASA drops them by design and for security purposes.
How to solve it? On the Endpoint device, the VPN server, the ASA on the office, you need to put the following command.
Crypto isakmp nat-traversal
And make sure that the Client its using it as well. That way the connection should run fine.
Hope this helps,
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008060f25c.shtml
Mike
Mike
Maykol Rojas
Hope this helps,
Mike
Mike
Thanks for taking your time helping me out, very appricated !
