split-dns || ERROR: % Input should be less than 256 characters.
armnandoh
Hello, community.
I am configuring a split-tunnel, when I add another domain to the split-dns value I am receiving this error: ERROR: % Input should be less than 256 characters.
I have found this is a bug CSCuz22961
Any suggestions if I require to add more domains in the split-dns value in the future?
Regards.
stsargen
Are you running a version of ASA code that has a fix for this issue?  If not you will need to upgrade.  Looks like 9.8.2 and later.
