Teardown TCP connection
Ibrahim Jamil
Level 6
Level 6
Hi Folks
what the below means?
Feb 07 2011 10:53:53: %ASA-6-3342014: Teardown TCP connection 1060547431 for outside:1.1.1.1/1258 to inside:192.168.1.10/443 duration 0:00:00 bytes 13809 TCP Reset-O
mirober2
Hi Ibrahim,
The message is stating that the ASA removed an HTTPS connection between 1.1.1.1 and 192.168.1.10 from its connection table because the client on the outside (1.1.1.1) sent a TCP reset packet.
Here is the syslog reference for the message:
http://www.cisco.com/en/US/docs/security/asa/asa82/system/message/logmsgs.html#wp6275532
Hope that helps.
-Mike
