Meraki devices suitable for Teleworkers
MiaColeman
What Meraki devices are suitable for Teleworkers and how can an IT Admin set up a Teleworker solution up at scale?
Mia
Philip D'Ath
The two best candidates would be the Meraki Z3 and the Z3C (the Z3C has built-in cellular).
https://meraki.cisco.com/en-au/products/sd-wan-teleworker/
To deploy at scale you create a template.  Typically you would allocate a supernet (for example /19) and the template will automatically allocate the addressing for you.
https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Managing_Multiple_Networks_with_Configuration_Templates
You can create the networks using a Python script and an API (there are many examples).  You can also use the bulk network creation tool and just import a CSV.
https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Using_the_Bulk_Network_Creation_Tool
helpcenterus
@MiaColeman , for setting up a Teleworker solution at scale with Meraki, you'll want to explore devices like the Meraki MX security appliances and Meraki Z-series teleworker gateways. The MX series offers robust security features, while the Z-series is specifically designed for remote workers. As an IT Admin, you can utilize the Meraki dashboard for centralized management, making it efficient to configure and monitor devices at scale. Consider creating a comprehensive network and security policy tailored for teleworkers, ensuring a secure and seamless remote work experience.
But the @Philip D'Ath  provided comprehensive information!
