AAA Configuration on ISE
CSCO11704570
Dears in Community
I have configured AAA in ISE 2.2. but I am receiving error of 13036 error message (selected shell profile is deny access) when it is authenticated in live logs.
paul
Level 10
Level 10
You would need to post a screen shot of your policy set and the details of the authentication hitting the Deny Access.  It sounds like your rules aren't configured correctly and you aren't hitting the rule you expect.
Along with the policy, I think you need to share your debug radius authen from NAD to match the sent attributes against the policy set.
ognyan.totev
Level 5
Level 5
Hello , go to Device administration -> policy elements >results >Tacacs command sets > create new command set like
permit all commands
Command Set
Commands
Tick the box and apply in sets and let us see what u configure in tripple AAA model in switch
hslai
Adding to the other comments, please check out the guides @ Device Administration (TACACS+)
