IP-phone Domain shows as DATA instead of VOICE
BigK
Can someone please explain why an IP-phone shows as data instead of VOICE
Device#sho authentication sessions
Interface MAC Address Method Domain Status Fg Session ID
Gi1/2   c4b9.cdb5.315e mab DATA Auth 000000000000000BC54A62F3
Device#sho cdp  neighbors
Device ID Local Intrfce Holdtme Capability Platform Port ID
SEPC4B9CDB5315e Gig 1/2 138 H P M IP Phone Port 1
interface GigabitEthernet1/2
switchport access vlan 10
switchport mode access
switchport voice vlan 50
device-tracking
authentication host-mode multi-domain
authentication open
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
mab
dot1x pae authenticator
dot1x timeout tx-period 10
spanning-tree portfast
end
BigK
2 Accepted Solutions
howon
You need to send down voice domain permission attribute from ISE for phone MAC address.Screen Shot 2019-02-07 at 10.55.01 AM.png
In the authorization profile (Policy->Policy Elements->Results->Authorization->Authorization Profiles) that you are applying to your Cisco IP Phone rule there is a center section called Common Tasks that has its own scroll bar.  If you scroll down just a bit  you will see the Voice Domain checkbox.
howon
@howon
Thanks !
How did you get there ?
