ISE 2.2 AnyConnect scaling with SGT, SXP
Peter Koltl
Level 7
Level 7
We are planning a two-node VM-3515 ISE 2.2 deployment for ASA and 6500 AnyConnect users with ISE posture and SGFW (SGT tagging and SGT based firewall rules and ISE-ASA SXP). Concurrent session number is about 100..300 so there is no scaling question with that. But the customer is considering Trusted Network Detection (or Always-on) with AnyConnect so I would like to know whether this deployment is capable of handling 6500 concurrent users.
Are there any changes if we upgrade to 2.3 later?
I see. if you're needing SXP via PXGrid then no it won't scale. You would need a 3595 in standalone which supports up to 10k SXP bindings and 20k active radius sessions
5 Replies 5
Jason Kunst
Sorry I am unclear of your question
Trusted network detection has nothing to do with ISE or scaling
ISE scaling all depends upon how many active sessions you have going at one time
Can you please clarify?
This is covered under https://www.cisco.com/c/en/us/td/docs/security/ise/2-3/install_guide/b_ise_InstallationGuide23/b_ise_InstallationGuide23_chapter_00.html
TND results in a lot more concurrent sessions (up to 6500 compared to 300) that's why we need to determine correct VM scaling. ISE Performance & Scale document has useful data but I am unsure about how to interpret SXP session number scaling guides and need help to determine if VM-3515 is able to handle 6500 AnyConnect/posture clients and SXP too. (Document says that Max ISE SXP Bindings is 3750)
No intent to use pxGrid, just SXP with ASA for SGT information exchange.
Please look at the numbers here. It indicates you would need a 3595 in standalone to support 6500 clients active at same time
https://communities.cisco.com/docs/DOC-68347#jive_content_id_ISE_SXP_Scaling_per_Deployment
