ISE Result - Customized Error Message On AnyConnect
Phi Yim
ISE experts,
My customer has the following AuthZ rule in ISE:
If Cisco-VPN3000:CVPN3000/ASA/PIX7.x-Tunnel-Group-Name=internal + authentication is EAP-TLS, then permit.  If an employee uses AnyConnect with their personal device without a valid client certificate, the end user sees the “Certificate Validation Failure”.  Please see screen capture below.
Is it possible for ISE to have AnyConnect display another message such as: “AnyConnect has detected that this machine is out of compliance”?
Timothy Abbott
Unfortunately, no.  ISE doesn't play a roll in the AnyConnect messaging for VPN authentication.  If AnyConnect were doing posture assessment, then you would have the ability to customize the posture messaging to the end user.
-Tim
Timothy Abbott
-Tim
Thanks for getting back to me Tim!
lnemec
Level 4
Level 4
Hi, sure, you can customize Anyconnect client error messages on ASA via ASDM.
Laci,.
