ISR4300 SM-X Compatibility with ISE
tgateri
Are the SM-X Ethermodules (SM-X-ES3-16-P, SM-X-ES3-24-P and SM-X-ES3D-48-P) running on an ISR4300 compatible with Cisco ISE for AAA, Profiling, Posturing and TrustSec. The ISE compatibility document here only mentions the ISR4451.
Titus Gateri
hslai
It's not listed because not tested by our teams. Craig said,
In the case of the switch modules, if the platform and code versions are identical to a standalone switch platform, then they should be included on the list, even if specific module not tested by QA.
hslai
