Manage Self-Signed Guest Account through Sponsor Portal (ISE2.2)
Filip Po
I can manage Self-Signed Guest Accounts through Manage Accounts in ISE menu (Work Centers > Guest Access > Manage Accounts. It open session on port 9002.
How can I manage this Self-Signed guest accounts through common sponsor portal on port 8445?
I will sign with user in group ALL_ACCOUNTS (default) and do not see any self-signed guest created account.
It is only way to manage Self-signed guest account through ISE menu - Manage Accounts, or do I have to change configuration to enable view of this type of guest accounts on sponsor portal?
Kind regards and thank you for help.
Filip
2 Accepted Solutions
Jason Kunst
Just checked in the lab. 2.2 p10 Self-Reg guests are visible under sponsor all account.
I would recommend working with the TAC.
After double check, I found particular sponsor portal user in bad Sponsor Group.
After change a group for the sponsor portal user everything work fine.
I can now see all guest accounts under Manage Account menu, and also under Sponsor Portal.
Please accept my appology. Can't say more.
No TAC required.
Jason Kunst
Researching this but looks like a bug so far. What version are you running?
I am running following version in production environment:
Version 2.2.0.470
Installed Patches 1,2,3,4,5,6,7,8,9
Product Identifier (PID) ISE-VM-K9
Version Identifier (VID) V01
Serial Number (SN)
ADE-OS Version 3.0.2.218
Jason Kunst
No TAC required.
