Monitoring and reporting in Cisco ACS
mvervoo31
We're currently running Cisco ACS 5.6 and I'm wondering which monitoring and reporting products are being used.
The monitoring and reporting tool in ACS does not meet our needs.
Eventually we will be migrating to Cisco ISE, so it would be good if the tool is compatible.
Suggestions are appreciated
Jason Kunst
Perhaps you can forward syslog to Splunk or another SIEM ? Check if they work with ACS and ISE they should but up to the vendor to consume the logs
Jason Kunst
Thanks Jason.
I'll check it out.
