Periodic AUP Acceptance - less than 8 hours?
danbates
I understand that I can use the Endpoint:LastAUPAcceptanceHours authorization condition to create a rule redirecting Guest users to a portal to re-sign an AUP when the AUP period has expired.  The Cisco ISE Administrator Guide, Release 2.1, gives the usable range of this AUP period as 8 to 999 hours.  Is it possible to reduce this time in order to require Guest users to re-establish their session as often as every 30 minutes?
Documentation source: Cisco Identity Services Engine Administrator Guide, Release 2.1  - Configure Guest Access [Cisco Identity Services Engin…
Jason Kunst
Please explain your use case and what you need want to do
Enhancement open to allow as low as 1 hour.
CSCuy24899 - Decrease the minimum value for LastAUPAcceptance check
ISE 1.4 Patch8
ISE 2.0 Patch4
ISE 2.0.1 Patch1
ISE 2.1 Patch2
7 Replies 7
Timothy Abbott
Daniel,
I don't believe so but maybe jakunst knows of a trick around it.
-Tim
Jason Kunst
ISE 1.4 Patch8
ISE 2.0 Patch4
ISE 2.0.1 Patch1
ISE 2.1 Patch2
Hi Jason,
I have a customer who wants to limit hotspot guest access to 30 minutes per session, and when the session expires, have the guests re-authenticate through the hotspot AUP page.
Why not require AUP on every login then and set session timeout via authz profile to 30 minutes? Would that work?
Warning: I either dictated this to my device, or typed it with my thumbs. Erroneous words are a feature, not a typo.
Not sure how that would work as endpoint is still registered and authorization is based off endpoint group and not hitting a portal until removed from that page.. Don't see this working
Of course you are right for a hotspot portal Jason. But, could they use a traditional guest portal, hide the username and password fields (prepopulate via script) and then require the AUP to be accepted?
George
Yes but then you're contemplating things, if 1 hour will work I would rather not get into that
