05-21-2018 01:46 PM
We just recently upgraded ISE from 2.3 to 2.4. One of our servers had a slow link 10 Mbps to copy the 9GB file over. It seems like it would time out of the GUI after 90 minutes. I was able to change the path of the file in order to get a faster speed and complete the copy. I thought I would share this for anyone doing a similar install.
GUI upgrade and 9GB file copy - 90 minute timeout.
The GUI would say that the download failed.
Alex
Solved! Go to Solution.
05-21-2018 01:51 PM
I performed something similar with 2.1 recently. The timeout in 2.1 was a third of what you were dealing with and it kept failing.
The easiest way for anyone that finds this is pretty simple.
1. Copy the upgrade file to disk: on each node via the CLI and FTP
2. Set up a repository from the maintenance tab that points at disk:
05-21-2018 01:51 PM
05-21-2018 01:57 PM
Thanks for the quick update. I will use this method in the future.
