10-29-2018 04:01 AM
I have been working with Wireless temperature sensor module to detect the temperature of machinery system used in industry but now we are trying to connect the system via internet cloud to store the embedded values of the temperature sensor using firebase. But to communicate these sensors with cloud we need to connect it through wifi whose IEEE standard are not similar as per Wireless sensors and receivers. So I need some advice about what is the best way to create the compatibility between this sensor and the firebase cloud. Any Leas will be a great help.
10-29-2018 02:58 PM
10-30-2018 03:18 AM
Hi the sensor device is using ZigBee X2C https://store.ncd.io/product/zigbee-mesh-xbee-pro-long-range-wireless-mesh-communications-module-external-antenna/ pro which is creating the wireless mesh network between the sensors
10-30-2018 03:20 AM
