IOT development devices for Wireless mesh network communication with Wireless Temp Sensors
Egzy76
Hi, We are recently working with the machinery industries HVAC system and has created the temperature monitoring system using a wireless temperature sensor.
But the monitoring system only creates the mesh network between their devices, but I am looking for the Internet gateway protocol device which helps us to send data to the online cloud.
Any suggestion will be a great help.
shearichards
You should try reaching out to some internet of things software development companies for qualified assistance. Good luck!
JoeSemos27769
Obviously, if you get Cloud then it will be easy to access data from anywhere. I agree with your answer...
bolick
This particular sensor would require a Zigmo gateway with support for Zigbee. You might want to take a look at LoRa sensors which generally have a greater range with lower power consumption. The gateway in that instance would be the LoRaWAN Gateway which could then interface with different on-premises and cloud applications.
https://www.cisco.com/c/en/us/products/routers/wireless-gateway-lorawan/index.html
