Using a Cisco 809 as a Serial Server over Cellular Link. Modbus Protocol to Modicon Device
kennemers
I am attempting to use a Cisco 809 as a serial server over cellular link.  I am trying to use the ASYNC 0 port without interfacing with the Virtual Machine, but rather directly to the hardware.  The serial devices I have at my disposal are Modicon Momentums and M340s with rj45 Modbus ports. Thus far I have been unsuccessful in this.  However, I have successfully polled a device over DNP3 to a SCADA-PACK RTU with a straight thru rj45 to rj45.  However, the Momentum and the base M340 are restricted to MODBUS.
Has anyone been able to make this work?
Thanks in advance for any help!!
Steve K.
Austin TX
below is the config:
SerialTEST01#sho run
Building configuration...
Current configuration : 3540 bytes
version 15.6
service password-encryption
hostname SerialTEST01
boot-start-marker
boot system flash:/ir800-universalk9-mz.SPA.156-3.M2
boot system flash ir800-universalk9-mz.SPA.156-3.M2
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR809G-LTE-NA-K9 sn FCW211900FB
username xxxx
redundancy
crypto ikev2 keyring SCADA-ring
peer xxx
address xxx
pre-shared-key local xxx
pre-shared-key remote xxx
crypto ikev2 profile SCADA-v2-Profile
match identity remote address xxx 255.255.255.255
identity local address xxx
authentication local pre-share
authentication remote pre-share
keyring local SCADA-ring
controller Cellular 0
lte sim max-retry 0
no lte gps enable
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
crypto ipsec profile default
set ikev2-profile SCADA-v2-Profile
interface Tunnel121
description "xxx"
ip address xxx 255.255.255.252
ip mtu 1376
ip tcp adjust-mss 1336
tunnel source Cellular0
tunnel destination xxx
tunnel protection ipsec profile default
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet1
no ip address
shutdown
duplex auto
speed auto
interface Wpan2
no ip address
ieee154 txpower 25
no ieee154 fec-off
interface GigabitEthernet2
no ip address
shutdown
duplex auto
speed auto
interface Cellular0
description “xxx”
ip address negotiated
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer watch-group 1
pulse-time 1
interface Cellular1
no ip address
encapsulation slip
interface Async0
no ip address
encapsulation raw-tcp
interface Async1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route xxx 255.255.255.255 Cellular0
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
dialer watch-list 1 ip 5.6.7.8 0.0.0.0
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
ipv6 ioam timestamp
snmp-server community S01arwinds RO
snmp-server enable traps wpan
control-plane
line con 0
login local
stopbits 1
line 1
exec-timeout 0 0
raw-socket tcp server 502
no exec
transport preferred none
transport input all
transport output none
stopbits 1
line 2
exec-timeout 0 0
no exec
transport input all
stopbits 1
line 3
script dialer lte
no exec
rxspeed 100000000
txspeed 50000000
line 8
no exec
rxspeed 100000000
txspeed 50000000
line 1/3 1/6
stopbits 1
line vty 0 4
login local
transport input xxx
no scheduler max-task-time
iox client enable interface GigabitEthernet2
end
Randall Birdsall
Hi Ken, I've sent you a private message to help get you an answer.
Thanks, Randy
