Intelligent Automation
“Webinar
Hi Team,I've developed a Python script to copy Tidal jobs on demand. While the dependencies are visible in the GUI, I'm unable to retrieve them through the API method. Below is my implementation: For copying a job:def copy_jobonly(path): jobid, p...
ppkuanr by Level 1
  • 564 Views
  • 0 replies
Hi All,I have a master which is running multiple jobs at a particular time. I am facing the issue of externally Defined for some of the jobs eventhough the said job completed successfully with the return code 0. Any help to fix the issue or any known...
Sadakoban by Level 1
  • 819 Views
  • 0 replies
Exception in thread "main" java.lang.IllegalAccessError: class taservices.d.g (in unnamed module @0x6ce253f1) cannot access class sun.security.action.GetPropertyAction (in module java.base) because module java.base does not export sun.security.action...
