Authentication Issue Tidal 6.2.1 Client
trombleyn
While attempting to login to the Tidal 6.2.1 Java Client, I am unable to do so as it just flashes and clears the password field out, however if I check the master logs I am receiving the following entry:
09/11 10:41:33:432[176:RpcServer Session]: (mem=1244562280/2141716480) ServerNode: Unable to authenticated user with error unauthorizeduser
We are using Active Directory security and have configured it successfully in our Development environment.
 I am also not able to access the Web Client version either. I have attached a screenshot of each. Web Client just shows System Initializing and System Logs. The above authentication error only logs when I attempt to go through the Java Client...the Web Client just continues to log the entries seen in the screenshot.
The only outstanding different between our Development & Test environments would be that we have a master backup (failover) configuration for the Test instance. I am seeing entries in the Master log stating Unable to connect to node run in PM mode on XXXXXXXX (server).
Thoughts?
Not sure if you got your issue resolved, if so please share here since this area is always helpful to new and experienced users alike.
In case you still haven't, just taking a stab here since its hard to answer without seeing you actual environment and how you did the upgrade what instance you used or copying configuration from:
  • Did you verify that the AD user you are using to authenticate Tidal user is correct and has correct password.  Did you populate the configuration files in the master and CM correctly?  For example here is mine :
Security.Authentication=ActiveDirectory
ActiveDirectory.Host=ourADserver
ActiveDirectory.Port=389
ActiveDirectory.UserSearchPrefix=DC=ourdomain,DC=pvt
ActiveDirectory.GroupSearchPrefix=DC=ourdomain,DC=pvt
or if using SSL, to authenticate:
ActiveDirectory.Host=OurADserver
ActiveDirectory.Port=636
LDAP.ForceBindingLogin=CN=ourADuser,OU=Security Groups,DC=ourdomain,DC=pvt
LDAP.BindPassword=##########
Security.SSL.enabled=Y
Security.SSL.trustStore=/ourfullpath/store.jks
Security.SSL.trustStorePassword=#######
