CPO XSL Transform for CPSC Form data with Grid
Jason Davis
Does anyone have an XSL Transform worked out that conveniently parses the CPSC Form output from Service Link when it has a grid in it?
For example the data from CPSC Service Link might look like:
<root>
   <Common>
      <Action ClassID="">Some Action</Action>
      <RequisitionID>123</RequisitionID>
   </Common>
   <Attributes/>
   <FormData>
      <Dictionary.Field>Some Data</Dictionary.Field>
      <DictionaryWithGrid-1.Field1>somevalue</DictionaryWithGrid-1.Field1>
      <DictionaryWithGrid-1.Field2>someothervalue</DictionaryWithGrid-1.Field2>
      <DictionaryWithGrid-1.Field3>yetanothervalue</DictionaryWithGrid-1.Field3>
      <DictionaryWithGrid-2.Field1>somevalue2</DictionaryWithGrid-2.Field1>
      <DictionaryWithGrid-2.Field2>someothervalue2</DictionaryWithGrid-2.Field2>
      <DictionaryWithGrid-2.Field3>yetanothervalue2</DictionaryWithGrid-2.Field3>
   </FormData>
</root>
So the desired output would be
<Row>
   <Field1>somevalue</Field1>
   <Field2>someothervalue</Field2>
   <Field3>yetanothervalue</Field3>
</Row>
<Row>
   <Field1>somevalue2</Field1>
   <Field2>someothervalue2</Field2>
   <Field3>yetanothervalue2</Field3>
</Row>
I'm having difficulty getting the right XSL select when the tag is something like 'DictionaryWithGrid-#.Field'.
Thanks!
2 Accepted Solutions
Try this...
<?xml version="1.0"?>
<xsl:stylesheet version="1.0"
      xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
      xmlns:msxsl="urn:schemas-microsoft-com:xslt">
<xsl:template match="root">
  <Table>
      <xsl:call-template name="ProcessOne">
        <xsl:with-param name="pos" select="1" />
      </xsl:call-template>
  </Table>
</xsl:template>
  <xsl:template name="ProcessOne">
    <xsl:param name="pos" />
    <xsl:variable name="RowName" select="concat('DictionaryWithGrid-', $pos)" />
    <xsl:if test="FormData/*[starts-with(name(), $RowName)] != ''">
      <Row>
        <xsl:for-each select="FormData/*[starts-with(name(), $RowName)]">
          <xsl:if test="starts-with(name(.), $RowName)">
            <xsl:variable name="FieldName" select="substring-after(name(.), '.')"/>
            <xsl:element name="{$FieldName}">
              <xsl:value-of select="."/>
            </xsl:element>
          </xsl:if>
        </xsl:for-each>
      </Row>
        <xsl:with-param name="pos" select="number($pos+1)" />
    </xsl:if>
  </xsl:template>
</xsl:stylesheet>
That worked great, Svetlana!  Thank you very much for the help.
I made some slight mods to make it even more portable and intuitive for XSL/XML beginners.
<!-- Replace CHANGEME below with the name of the CPSC Form Dictionary to transform -->
<xsl:variable name="Dictionary">CHANGEME</xsl:variable>
  <Table>
  </Table>
</xsl:template>
    <xsl:variable name="RowName" select="concat($Dictionary, '-', $pos)" />
      <Row>
            </xsl:element>
          </xsl:if>
        </xsl:for-each>
      </Row>
    </xsl:if>
  </xsl:template>
</xsl:stylesheet>
Try this...
  <Table>
  </Table>
</xsl:template>
      <Row>
            </xsl:element>
          </xsl:if>
        </xsl:for-each>
      </Row>
    </xsl:if>
  </xsl:template>
</xsl:stylesheet>
  <Table>
  </Table>
</xsl:template>
      <Row>
            </xsl:element>
          </xsl:if>
        </xsl:for-each>
      </Row>
    </xsl:if>
  </xsl:template>
</xsl:stylesheet>
