Auto create request by reading a row in MS SQL table?
If all required data for a particular request type were included in a row of a MS SQL db table (staging table), could a request be created using a db adaptor?  Or is web services the only option to auto create a request?
By definition, a DB adapter is part of ServiceLink and ServiceLink handles task-level integration, ie, it can externalize a task that's in a request that already exists. Web Services is the only option to create a new request.
