BMC Remedy - Polling
marlo.777
Community Member
Hi Everyone,
For those with experience on using the BMC Remedy Adapter on Cisco's Process Orchestrator (CPO) 3.5, I would like to know if there's a way to do polling from/using the adapter? or what the best polling mechanism for CPO to do this is currently?
I noticed there was a "Polling" property on the BMC Remedy target, but I'm not clear on how it's intended to work or be used.
Thanks.
Tiberio Martinez
Community Member
Hi Mario,
The adapter does the polling for you, so you can focus in capturing the events that trigger your processes in CPO.
Hope this helps,
Tiberio
