Can we have silent installation for Cisco prime service catalog (CCP)?
vasu44401
Community Member
HI,
I want to install Cisco prime service catalog(newscale) in silent mode, which version supports this feature.
And also please provide any related docs.
Thanks in Advance
Srini.
5 Replies 5
sotoh
Level 3
Level 3
Srini,
We don't yet support silent install for the prime service catalog but there is something being done in our lab.  What is your use case and can you share other details?
Thanks.
Song
Hi Sotoh,
I have a similar situation as Sirini. I also want to install it silently.
can you please share some guidelines and pointers on how did you setup it in your lab.
Thanks.
FYI, I had created an enhancement request for silent install: CSCui67721
vasu44401
Community Member
sotoh,
I am using puppet(configuration mangement tools) which manages several nodes.
so i want to install CIAC on many  nodes with same configuration with reusable silent install using puppet manifest files.
Has there been any progress on this in the last few years?
