Dependencies status question
jefffestejo
I am trying to configure jobs dependencies to kick off if the jobs completed normally or abnormally. I am looking to use the status "completed".
By using "completed" will this satisfy either normal or abnormal
Derrick Au
Level 4
Level 4
Hi Jeff,
That is correct. When job dependency is set to completed, then it satisfied when job either completes normally or abnormally.
BR,
Derrick Au
It will satisfy in both normal and abnormal completion
Hi Dinesh,
I believe you've beat me to the punch line. I was still fiddling around with my spell checker at that moment :-]
Cheers,
Derrick Au
Derrick Au
Level 4
Level 4
Hi Jeff,
BR,
Derrick Au
