DST Tidal Workload Automation
Kenneth Kuchynka
All,
It is that time of year again and DST time change is upon us again.  The team has put together a DST doc that covers know issues with the product build these issues were addressed in.
Since the following item was recently discovered the development team has provided a utility that will allow you to see any jobs that might be affected by this issue.
Problem: Jobs are not compiled into the schedule on the previous day to daylight change when the job’s until time carries over to DST day.  a. Root Cause: When the job’s until time falls after DST shift, Master calculates the until time to a negative value causing the job to miss the schedule on the previous day to daylight change. b. Fixed in version: 6.2.1.796, 6.3.3.35
            Note: Customers in 6.3.1 and 6.3.2 will need to upgrade to 6.3.3 for the above fixes.
             Please Click The Following Link To Download DST Doc And Utility
https://cisco.box.com/s/bapbd5xvc9c4l8f0cd84md7pd4dmgy16
