Error message when submitting PS job in Tidal
Lumi Mihalcea
Did anyone see this error message? I submitted a PeopleSoft job and got this message
org.apache.xerces.dom.ElementNSImpl cannot be cast to org.w3c.dom.html.HTMLAnchorElement
All I can find in the log is where it changes the status to 66, Error Occurred. Is it Tidal or PS?
Lumi Mihalcea
Found the problem, not Tidal...part of the navigation was missing due to a permlist in PS
Hi Lumi,
Out of curiousity what version of PS is your environment? i recall seeing a thread from you asking about the PS 9.2? just wondering if 9.2 is now compatible with TES 6.0.3 or 6.1
Hi Rami,
we are on PeopleTools 8.53
Thanks Lumi
I hope its working fine with you, my client is thinking about upgrading their PS from 9.1(PTools 8.50.10) to PS 9.2(PTools 8.53) and I wanted to make sure that TES can still talk to the new PS env with no issues.
Seems i also need to research Informatica as well, as we have WS connection between Infomatica and the PS env. do you have Informatica as well? if so, is everything working as expected.
appreciate this Lumi.
