Form enrichment
jlouvet
Hi, Can a form or service be presented to a client a certain way, then once ordered it goes to an approver or another service team to be enriched with additional information (via fields/forms that the original client had no access to) ? Thanks.
mpavlish
The short answer is "yes".
The long answer is that there are multple ways to achieve this. I highly recommend reviewing "Cisco Service Portal Designer Guide" as it contains detailed instructions on how to design a service.
You can find it here:
http://www.cisco.com/en/US/docs/net_mgmt/datacenter_mgmt/intel_auto/service_portal/v9_4_0/user_guides/CiscoServicePortal_9_4_0_DesignerGuide.pdf
Max.
