FTP Job failed: Illegal characters in path
adminvest
I have setup a FTP job in Tidal but it keep failing. The error is "Illegal characters in path" I have double check all the path setting in the FTP job everything seems ok. Any ideas?
18 Replies 18
adminvest,
Can you please the following cases,
1) a filename that actually exists on the remote server
2) partial filename followed by "*" ie, partial_filename*
3) *.*
Derrick Au
No luck, same error.
adminvest,
Which Tidal Master version are you using? and which Tidal agent version are you using?
In regards to the problem with spool file, Tidal error listing suggests:
Problem with spool file for job %%1.
2102
There was a problem with the job script or the environment file for the given job:
The job’s script file does not exist or cannot be read.
The job data string sent by the master was corrupt.
There was an error transferring the job script from the master to the agent.
There was an error transferring the environment file from the master to the agent.
adminvest
Actually I am still having issue, we were able to change the file name in the source server and removed the % sign from the file name. We are still getting the same error message.
The new file name we are trying to get is:
WIRE.XXX20150914093444.csv
is there any problem with this file name?
