Garbage entries in Orchestration Server :: Responsibilities
Anish Somadevan
I can see in my CPO's Orchestration Server properties - Responsibilities tab, there are 3 entries for AMQP Subscription. Out of the 3, i use one in some of my workflows. But the other two  "Unknown(some id)" are not available in the CPO and not used in any process or workflows. Am not able to find these entries under AMQP targets. I tried restarting the CPO service to see if these entries get flushed out. But it didn't work either. Can anyone please explain how to remove these entries?
Orchestration server :: Responsibilities tab
Anish
Shaun Roberts
Did you have AMQP targets before and then delete them or something?
Probably something hanging in the DB that should have been removed. I would suggest a TAC case and have them investigate.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
Shaun Roberts
--Shaun Roberts
shaurobe@cisco.com
Yes Shaun, I had some created and deleted them a week back. Can you please let me know what is the table that i need to look into ?
We would not suggest that anyone get into the tables and do any direct work without TAC or Cisco engineering assistance. All configuration is stored in the dbo.Configuration table but there might also be some keyed links to other tables that you might not know without knowing the root schema of the CPO Process DB.
--Shaun Roberts
shaurobe@cisco.com
Thanks a lot for the info Shaun. I will raise a TAC and try to get this investigated and resolved.
Thanks again !! :)
