Going from TES 5.2 to CWA 6.3....
Jason Schilling
Hey Everyone,
Currently having quite a hard time trying to figure out how to go about migrating all of my jobs from one environment (TES 5.2) to our new environment (CWA 6.3).
Both are running on windows and using MSSQL DBs in completely seperate environments that cannot access each other.
So the question: Outside of manually recreating every job I have (4,500+ jobs), is there any way I can export these from 5.2 and import to 6.3?
I was hoping the DB schema would be the same (I have a copy of the old DB on the new servers), but it appears they are not. I am also not sure if transporter for 5.2 (if it even exists) would be compatible with the transporter from 6.3 as well.
If not, any ideas what the easiest way is to go about doing this?
The Transporter uses APIs to copy the components over. So the db schema change ideally does not impact Transporter. However, the link below says "you cannot transport between a “pre- 5.3.1.362” master and a “post-5.3.1.362” master"
http://www.cisco.com/c/en/us/support/docs/cloud-systems-management/tidal-enterprise-scheduler/113512-tes-mct-master.html
