How do I access Performer Name?
Carol Josefek
We need to be able to get the Name of the Performer of a specific task to pass to a downstream system. Anyone had success doing that?
Emir AmEx (9.1)
how are you going to pass this name? Via SevriceLink?
Carol Josefek
Yes.  I was trying to capture it as a field on the form during the performer task moment.  Then on the next task (which is the one that ultimately connects via Service Link) I would map that field to the appropriate property.
Emir AmEx (9.1)
I think the nS XML, the message BE sends to SL, has this info in it, please review that message.
Otherwise run a SQL statement against RC DB as a data retrieval rule onLoad during SD Moment and taskname = your task, and write it to a field that will be passed.
Did you try default value for the field to be #Performer.Name# ?
