How to execute a PL/SQL Stored procedure from CPO ?
apriydar
Is there a way to execute a stored procedure from CPO, if yes then please explain how can we do that ?
Shaun Roberts
Use the "Execute SQL Server SQL Script"
use the SQL command
EXEC
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
I am using Execute Oracle SQL Scripts
My script is - EXECUTE testproc;
I get following error - ORA-00900: invalid SQL statement
However it works on TOAD.
You need to be careful you do not have an extra space around the statement or in it or something. If you need further help please open a TAC case and support can help.
--Shaun Roberts
shaurobe@cisco.com
